Hello
I once burned out a cmoss 4066 ic due to me putting the battery on backwards and so I thought to stop this happeneing again I should protect my circuit with a diode. Now I was wondering whether it is best to put the diode on the positive side of the circuit or facing back to the battery on the negative side.
I was thinking this because if I have an IC in my circuit and normally when battery is the right way roung positive is gioing to the positive pin and negative is going to the negative pin of the IC. If the diode is on the positive side and I reverse the polarity, nothing can go back to negative as the diode is stopping it but the positive of the battery is giong into the ground pin of the IC
However if the diode is on the negative side when I reverse the polarity nothing at all can get to the IC as the diode is stopping the positive getting to the ground Pin. Do you see what I am saying?, I have attached a basic circuit diagram to illustrate this.
What do you say is best putting the diode on the positve or negative side?
Thank you for reading and any replies.
