PT1000 temperature sensor calculation
adrianvon
Hi all,
I am going to use a PT1000 temp sensor for my project. From the data-sheet one can notice that the resistance is 1000ohms when the temperature is 0°C.
Now i want to determine the resistance for, lets say 40°C. Is there a formula or something to determine this?, since it is hard to determine the respective resistance from the graph given in the data-sheet.
(Attached please find the PT1000 datasheet)
Thanks in advance.
  • pdf-14_38_68.pdf
Look at these pdfs
  • PT100dta.pdf
  • Resistor_table_Pt1000.pdf
Thanks for your fast reply ericgibbs :)
I will use the second PDF file which includes the table to calculate the resistance for a specific temperature.
Ericgibbs,
In the attached table (taken from the second attached file), do you know what are the numbers in the x-axes? (i.e. 0 1 2 3 ... 9 0)
Another question; I calculated that the resistance vary 3.9ohms for every degree Celsius ((1000 - 1039)/10). Is that correct??
They are increments of 1C from left to right of the extreme left column
eg: 80 81 82 83 84 .....
90
The datasheet suggests +4R/C will be close
