sciencetoolbar
To build the pulse motor generator (educational purpose, refering to the presented model) I used :
Power: 1.2W
Current: 240 mA
Material: Monocrystalline
Size: 110 x 69mm
4. Step-up Module with adjustable booster power supply module
6. bobbin – coil iron less used to produce a repulsive force ("input coil") - from an electromagnetic door hold-open device
7. a reed switch
8. led circuit from an emergency exit sign
I wish to mention that the pulse motor generator presented is an educational project and is not breaking physics laws
- fidget spinner with iron insertions – the flywheel – PMG rotor
- three neodymium magnet discs
- two small solar panels – power source
Power: 1.2W
Current: 240 mA
Size: 110 x 69mm
- AeroSemi MT3608 1.2MHz 2A Step Up Converter
- 2A maximum output current
- 2.0 to 24VDC input voltage range
- 28V maximum output voltage (trimpot adjustable)
- 93% peak efficiency (~200mA output current at 5Vin, 12Vout)
- 36 x 17 x 14mm
7. a reed switch
