kasamiko
I'm going crazy with this..![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I'm using 16F628A to generate modulated 40khz to drive an infrared led and a tv infrared remote control receiver as detector...
here is my PWM code below:
but I can't make it works...![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I also tried using 556 which is the 40khz oscillator is gated by another 250hz oscillator but still doesn't work!
Any ideas will be appreciated...
TIA
@ DEVICE HS_OSC,MCLR_OFF,LVP_OFF,WDT_OFF,PROTECT_OFF
DEFINE OSC 20 ' We're using a 20MHz crystal
CCPR1L = 25 ' 25=20% PWM Duty-Cycle
PR2 = 124 ' Set PWM for ~40KHz
T2CON = 4 ' Timer2 ON + 1:1 prescale
TRISB=%00000100 ' Set PortB TRIS register
PORTB=%00000011 ' LEDs off, pulsout pins set for logic 1 pulses
TIA
