max_imum2000
Hello there
i am trying to make a circuit that controls 6 DC motors (12-24volt) (1-2amp),
3 variables should be there, speed (PWM), Direction (For & Rev) , and duration which the motor should work then stops.
i intended to use L298 for each 2 motors.
i wonder what is the best PIC i can use to do this job. i really need it to be cheap and to control as much L298 as possible.
i am thinking of using 2 PIC16F84 , each PIC controls 2 L298 dirversr and each L298 controls 2 motors.
then i control the 2 PIC16F84 with another larger PIC to handle all the communications between the PC for example and the other circtuit
what do you think, ?
i realy need your opinon
thank u
thank u
