Can I use it as a replacement of 38KHz crystal? (in NJM2035 based stereo encoder) in here www.electronics-diy.com/stereo_encoder.php Please
I guess the input signals would be then low-passed at 16KHz, but the also might overlap in the narrower band. Also, you wouldn´t be able to decode the joint stereo back into separate channels without the same freqeuncy decoder, even though the sound coming out of a 32-38khz encoder-decoder combination might be very interestingCan I use it as a replacement of 38KHz crystal? (in NJM2035 based stereo encoder) in here www.electronics-diy.com/stereo_encoder.php Please
You could but then it wouldn't properly decode the FM stereo signal which has a subcarrier of 38KHz.Can I use it as a replacement of 38KHz crystal? (in NJM2035 based stereo encoder) in here www.electronics-diy.com/stereo_encoder.php Please
=WTP Pepper;1061952changing it generally will cause all sorts of odd problems (clocks running fast/slow etc).
Edit: or mabye not, since this uses time-division multiplexing and the decoder will fall back to mono mode if it doesn´t receive the 19khz carrier.
