Im building a tesla coil. Id use a NST but they dont seem to easy to get here in the uk. So ill be using mots.
My coil will be a 10cm x 50cm so approximately a 4 inch coil and 8KV (4 mots) 1000W
ill use 4 mots to give me 8kv and ive got tesla map to figure out roughly the right capacitance for the mmc and some other things.
What i realised from that is that if i up the current output ill need significantly higher capacitance for the mmc. So id like the max current from the secondary to be around 125ma.
Im still in the process of learning and understanding inductive reactance properly. And im confused by the mots hooked up and what their resistance/reactance would be or what determines how much current they draw.
So I need to know what inductance id need for the ballast so that the secondary draws no more than 125ma and the primary draws no more than (1000/230) which is about 4.35A. Or perhaps an idea on how id go about working this out.
I also realise with the ballasting that the 230 input will be split between the ballast and the mots so the mots wont have 230V but a fraction. With the inductive ballasts no power will be lost but i think the voltage is still split just the phase is altered at the same time. so how is this counteracted. or am i wrong and with inductors something different happens.
