Question about registers in 16F628A, banks
kcn
In one of Nigel's tutorials (Tutorial 6.1 to be exact), he defines in his code
		cblock	0x20			;start of general purpose registers
			count			;used in looping routines
			count1			;used in delay routine
			counta			;used in delay routine
			countb			;used in delay routine
			LoX
			Bit_Cntr
			Cmd_Byte
			Dev_Byte
			Timer_H
			Flags
			Flags2
			tmp1			;temporary storage
			tmp2
			tmp3
			templcd			;temp store for 4 bit mode
			templcd2
			lcdtmp
			Adr_Lo			; EEPROM memory address to be accessed
			Adr_Hi
			DAT_VAL
			_N
			InputByte		; byte read from EEPROM is stored in this register
			Data_Page		; EEPROM page, 0-7
			OutputByte		; used for holding byte to be output to EEPROM
			I2Cflags		; flag bit register
		endc
Is each one of these "variables" (to sort of speak), exactly one byte?
Are these "variables" only accessible when you are in bank 0?
If the cblock 0x20 were changed to cblock 0xA0, would the "variables"
only be accessible when you are in bank 1?
Suppose I executed the following code
        movlw 0x20
        movwf fsr
next    clrf indf
        incf fsr
        btfss fsr, 2
        goto next
would the effect of this code basically set count, count1, counta, and countb all to zero? Would this only work when I am in bank 0?
Thank you.
kcn
Hi again kcn,
         LoX
         Bit_Cntr
         Cmd_Byte
         Dev_Byte
         Timer_H
         Flags
         Flags2
         tmp2
         tmp3
         templcd2
         lcdtmp
         Adr_Hi
         DAT_VAL
         _N
      endc
Yes, each variable is one byte...
Yes and no... You can access them by name in operands when in Bank 0... You can access them indirectly using the FSR and INDF registers with the STATUS register IRP bit = 0 (you can indirectly access 000..0FF with IRP=0 and access 100..1FF with IRP=1)...
Yes and no... You can access them by name in operands when in Bank 1... You can access them indirectly using the FSR and INDF registers with the STATUS register IRP bit = 0 (you can indirectly access 000..0FF with IRP=0 and access 100..1FF with IRP=1)...
        movlw 0x20
        movwf fsr
next    clrf indf
        incf fsr
        btfss fsr, 2
        goto next
Yes, this code would clear locations 20h through 23h... You can access 256 contiguous locations using indirect addressing... Locations 000h through 0FFh with the STATUS register IRP bit = 0 and locations 100h through 1FFh with IRP = 1... Pretty wierd, huh?
Regards, Mike
