Question about relating thermal fuse ratings
omgwtfbyobbq
If I have a thermal fuse, rated for say, 10A at 100C. Would there be another fuse rated for less current but higher temperature that would open at the same point the 10A/100C fuse does? If so, what's the relationship between the two?
Does this apply to thermal switches as well? Can I use fuses with different current ratings provided the temperature rating is the same?
If the current flowing causes a significant temperature rise it will cause it to blow at a lower ambient temperature which is normally a good thing.
