Space Varmint
Hi, I'm looking for some good suggestions on doing a voltage interface. I really need it to be hyper responsive.
Here is the scheme: I will be running a complete system off of one 6 volts DC supply. There is a DC2DC converter on board. It will produce 150 volts DC but uses a different ground. I need an interface that uses a variable voltage produced from a 6 volt device to vary the 150 volts. What would be the simplest approach to this? Maybe some sort of differential amplifier arrangement? I'm not sure where to begin.
