danrogers
im looking at the datasheet.. **broken link removed**
and noticed it states the low battery out put and also the data outputs low low wen operated. Does that mean that I would connect a led to the vcc (5v) and the gnd to the pin on the ic, same with the outputs, would i connect a relay to the vcc and its ground to the relevent pin on the ic?
thanks!
thanks!
