quizz buzzer to go to 12 volts help
jace33
Thanks for taking the time to look at this but would like some advice into how to convert this to a 12 volt project as i want to use 12 volt lights instead of led's any help on how to do this would be helfpfull
thanks
  • VEMK133.pdf
It depends on how much current your light bulbs use. If the current is low then why bother changing the value of each current-limiting and sensing resistor connected to the LEDs. A low current light bulb is dimmer than an LED.
If your light bulbs use a higher current so they get nice and hot then the entire circuit must be re-designed.
