R equal
R equal in this circuit ?
ALL R in picture have equal value.
there is one resistor in each leg.
Two are missing, if there is to be one resistor in each leg.
I've seen this problem before, and worked out the answer, but I don't remember what it is.
This sounds like homework. Post your answer, and how you got it. Maybe then you'll get some replies.
ok , there is one resistor in each leg.
Perhaps, in your problem. The drawing is missing two resistors.
Edit: Add attachment
Tom_electronic, are you sure you identified the correct corners for the equivalent resistance? The problem as I have seen it defined was for diagonally opposite corners.
