radial electrolytic caps - R.C.
Boncuk
I've just downloaded a datasheet for radial electrolytic caps.
There is a numeric value for R.C., which I suppose stands for the pin distance.
Can anybody shed some light on the numbers and what is the basis for calculating the pin distance, e.g. 1,000µF/63V has an R.C. value of 1930.
Boncuk
hi Hans,
The RC on devices often refers to their country of manufacture,,,, RC Republic of China.
Regards
Hi Eric,
welcome back and a happy New Year.
I guess R.C. doesn't stand for "Republic of China", since for each cap the R.C. number is different.
I'll attach the datasheet for your reference.
Designing a new circuit without proper dimensions of the caps to be used is somehow wasted time.
Kind regards
Hans
  • ELKOS-RADIAL-01.pdf
Could it stand for Ripple Current?
The chart labeled "case size & max ripple current" has two columns. One is DxL (Diameter x Length ?) and the other is RC (ripple current?). Top note says size is mm, current mA.
Since they are radial caps, the lead spacing is some appropriate radius away from the end of the device.
I hate incomplete datasheets. -:(
The pin spacing is on the first page. In the Dimensions table, first look up the diameter of the cap across the top then go down to the F value. That is your pin spacing.
In this particular case, R.C. == ripple current.
Got it.
Thanks a lot, smanches.
Boncuk
