Jay.slovak
Active Member
Hi guys,
My Philips TV's remote died, and I need to tune-in some new stations. I have a replecement remote, but it can only do some basic comands (volume, station, off). So I was thinking, I can build a remote with a PIC. (I only want it to send the required Tuning functions)
I studied I bit. Found out RC-5 encoding principle.
I connected a LED directly (via 180ohm resistor) to 18F2620 (was at hand) CCP2 output. I realize this will produce a very weak IR signal, but I only need it to tune-in new stations. So far, I can produce modulated IR signal at 36.31Khz with 889uS deleys between modulation pulses as seen on these **broken link removed**. I am using CCP2s PWM fucntionality to generate 36Khz carieer, and I modulate it by altering TRIS register. I used my digital camera in night vision mode and my Hi-Fi set (which flashes a LED everytime it sees a carieer) to confirm this technique works. My TV, however doesn't react to Device code 0 and function code 0.
My question (to anybody who has done this before, maybe Nigel
) is what is the requered precision of the carieer freq. (eg. will it accept 36.31Khz ?) and how precise should the time-slots be? The source states: "Constant bit time of 1.778ms (64 cycles of 36 kHz)"
Any advice will be helpfull.
