rca audio
SNIPE
Banned
how do i get the RCA audio jacks to work with the component sources, it should only work with composite as its part of that PCI-e card
they is PCI 2 cards one is component video and the other is composite video and rca audio
the TV will only accept RCA and composite in 1 signal, when i go to the component and use the RCA audio jacks i don't get any audio
here is the 2 PCI cards used:
http://www.dvhardware.net/news/amd_all_in_wonder_hd.jpg
You'd need an external mixer, you can't just use a simple adapter to connect these signals together, they're not compatible with each other.
is they a way to split the signal from the jacks to the pins on the north bridge or pci
so the audio will be wired up to the other set of audio pins on the north bridge or pci slot
Yeah sure if you want to trace the signal lines you need break them and wire them over to the other board. I hope your soldering skills are top notch those boards are generally pretty fine pitch. You may pick up interference using wires between the two boards or possible a ground loop, who knows they're not designed to be rewired so it's a crap shoot.
