rollinstonedj
I have a Peavy mixer with enough inputs but only 2 outputs. Does someone have an idea on i could add additional outputs without signal loss ?
rollinstonedj said:I have a Peavy mixer with enough inputs but only 2 outputs. Does someone have an idea on i could add additional outputs without signal loss ?
gifford said:good question. One I would like to know the answer to also...
Nigel Goodwin said:gifford said:good question. One I would like to know the answer to also...
Also see my previous reply!.
gifford said:Well I was hoping the original poster would have piped up, as I didn't want to steal his thread, but OK here goes...
I have two audio amplifiers (one for bass & one for mid/highs), however I only have one RCA source from my CD player, and would like to split it.
I heard there was a loss in signal if I simply split the original signal, is this true?
Nigel Goodwin said:gifford said:Well I was hoping the original poster would have piped up, as I didn't want to steal his thread, but OK here goes...
It's all to do with impedances - a preamplifier (or CD player) should have a low(ish) impedance output, and an amplifier should have a high(ish) input impedance.
The output impedance of the CD player, and the input impedance of the amplifier form a potential divider - this reduces the output by a certain amount, which should be negligible. Adding a second amplifier puts the two input impedances in parallel - giving half the impedance, this will cause the output to fall by another small amount - but again, this should be negligible.
For your purposes it should work fine, and you shouldn't notice any difference between one or two amplifiers connected.
gifford said:So if I worked out the signal drop, a small amplifier chip would resolve the situation.
rollinstonedj said:Hey - Its Ok that you jumped in- I had to leave for work.As long as i can find a solution.I have used splitters on the outputs in the past - and Yes i do notice a difference in signal loss.I use a computer as my main source of music -2 channels line input,also 2 cd players going in(as back up).The peavy mixer has only 2 main outputs for the amps - I want to add 2 or more outputs for 4 amps .I guess i'm looking for a quick show me how and what stuff i have to get. Thanks
rollinstonedj said:Wow I thought it would be a simple trip to Radio Shack, put this & that together and be on my way.I'd like to ad the outputs inside the Peavy mixer (saving space & weight).I'll try to go to their site and see what they have for my model.Thanks for taking the time with me.
