extremeads1
i see a transmitter RCT-433 AS always used in projects as a transmission device.i want to do a manually controlled car using microcontroller and this transmitter , i wish that that when i press the forward button the car will move forward and when i press the left,reverse,right buttons the car will move so respectively. so can these forward/reverse or left/right signals be transmitted using this module ? MOrever i'm going to add some circuits on the car like metal detector,heat detector and distance detector so when i will request these functions to the TXMCU would these signals along with the car control signals be transmitted to the car RXMCU.and if it is possible the result of the requests should again be transmitted by the CAR RXMCU to the TX MCU.does this form a duplex system or what ? and is it posible to achieve it ?
