Dear Sir,
I need help from converting coding from Basic PIC Pro to MikroC language. I've tried to read the coding samples of Basic PIC Pro but i couldnt follow up. Please help me out.
The coding are:
DEFINE OSC 8
DEFINE LCD_DREG PORTD;
DEFINE LCD_DBIT 4;
DEFINE LCD_RSREG PORTC;
DEFINE LCD_RSBIT 4;
DEFINE LCD_EREG PORTD;
DEFINE LCD_EBIT 3;
DEFINE LCD_RWREG PORTD;
DEFINE LCD_RWBIT 2;
//Define ADCIN Parameters
DEFINE ADC_BITS 10
DEFINE ADC_CLOCK 3
DEFINE ADC_SAMPLEUS 50
ADCON1=%10000010
TEMP1 VAR WORD
TRISB=%00000000
TRISD=%00000011
TRISC=%11101100
ADCON1=%10000010
SET1=300
SET1 VAR WORD
ADCVA1 VAR WORD
LEFT_FWD VAR PORTB.3
LEFT_REV VAR PORTB.4
RIGHT_FWD VAR PORTB.2
RIGHT_REV VAR PORTB.5
PAUSE 1000
LCDOUT $fe, 1
MAIN:
GOSUB READ_SENSOR
GOSUB DISPLAY
GOSUB COMPARE
GOTO MAIN
END
DISPLAY:
LCDOUT $FE, 2
LCDOUT "SENSOR = ",DEC TEMP1," "
LCDOUT $FE, $CO
LCDOUT "SETTING = ",DEC SET1," "
PAUSE 100
RETURN
COMPARE:
IF TEMP1 <= SET1 THEN
GOSUB MOTOR_FWD
GOSUB MOTOR_STOP
ENDIF
IF TEMP > SET1 THEN
GOSUB TURN_RIGHT
GOSUB MOTOR_STOP
ENDIF
RETURN
READ_SENSOR:
ADCIN 0, adcval
TEMP1 = adcval
PAUSE 5
RETURN
MOTOR_FWD:
HIGH RIGHT_FWD
HIGH LEFT_FWD
LOW RIGHT_REV
LOW LEFT_REV
PAUSE 100
RETURN
MOTOR_REV:
LOW RIGHT_FWD
LOW LEFT_FWD
HIGH RIGHT_REV
HIGH LEFT_REV
PAUSE 200
RETURN
TURN_RIGHT:
LOW RIGHT_FWD
HIGH LEFT_FWD
HIGH RIGHT_REV
LOW LEFT_REV
PAUSE 200
RETURN
MOTOR_STOP:
LOW RIGHT_FWD
LOW LEFT_FWD
LOW RIGHT_REV
LOW LEFT_REV
PAUSE 10
RETURN
The coding are:
DEFINE OSC 8
DEFINE LCD_DBIT 4;
DEFINE LCD_RSBIT 4;
DEFINE LCD_EBIT 3;
DEFINE LCD_RWBIT 2;
DEFINE ADC_BITS 10
DEFINE ADC_CLOCK 3
ADCON1=%10000010
TEMP1 VAR WORD
TRISB=%00000000
TRISD=%00000011
TRISC=%11101100
ADCON1=%10000010
SET1=300
SET1 VAR WORD
ADCVA1 VAR WORD
PAUSE 1000
LCDOUT $fe, 1
MAIN:
GOSUB READ_SENSOR
GOSUB DISPLAY
GOSUB COMPARE
GOTO MAIN
END
DISPLAY:
LCDOUT $FE, 2
LCDOUT $FE, $CO
PAUSE 100
RETURN
COMPARE:
GOSUB MOTOR_FWD
GOSUB MOTOR_STOP
ENDIF
IF TEMP > SET1 THEN
GOSUB TURN_RIGHT
GOSUB MOTOR_STOP
ENDIF
RETURN
READ_SENSOR:
ADCIN 0, adcval
TEMP1 = adcval
PAUSE 5
RETURN
MOTOR_FWD:
HIGH RIGHT_FWD
HIGH LEFT_FWD
LOW RIGHT_REV
LOW LEFT_REV
PAUSE 100
RETURN
MOTOR_REV:
LOW RIGHT_FWD
LOW LEFT_FWD
HIGH RIGHT_REV
HIGH LEFT_REV
PAUSE 200
RETURN
TURN_RIGHT:
LOW RIGHT_FWD
HIGH LEFT_FWD
HIGH RIGHT_REV
LOW LEFT_REV
PAUSE 200
RETURN
MOTOR_STOP:
LOW RIGHT_FWD
LOW LEFT_FWD
LOW RIGHT_REV
LOW LEFT_REV
PAUSE 10
RETURN
