blueroomelectronics
It's a reaction time, the program is crude but runs fine. You'll need JUNEBUG.BAS (download from my site) and it uses the PICkit2 UART tool to display your results.
When LED 1 lights press button #1.
Your time was 0.835040 Seconds.
Your time was 0.166864 Seconds.
Too Slow, press RESET to try again.
Too Soon! You have to wait till LED #1 is lit.
* Name : ReadySteadyGO.BAS *
* Author : William Richardson *
* Notice : Copyright (c) 2008 blueroomelectronics *
* : All Rights Reserved *
* Date : 3/3/2008 *
* Version : 0.9beta *
* Notes : LEDs 3,2,1 countdown, press button #1 as soon as LED 1 is lit
* : DIP Switch #4 must be on to see results using PICkit2 UART Tool *
Device = 18F1320
Clock = 8 // 8MHz clock
Include "junebug.bas"
Include "convert.bas"
Include "usart.bas"
Dim Qualify, Temp As Byte
Dim Time As string ' total time in us
Interrupt ButtonPress()
T0CON.7 = 0 ' stop the timer
If Qualify = 0
Then
Write("Too Soon! You have to wait till LED #1 is lit.",13,10)
LED(6)
Else
temp = Tmr0l ' loads TMR0H
Time = dectostr(((tmr0H*256)+Temp)*16,6)
Write("Your time was 0.",Time," Seconds.",13,10)
LED(4)
EndIf
INTCON.4 = 0 '
While true
Wend
End Interrupt
OSCCON = $72 // 8 MHz clock
SetBaudrate(br9600)
INTCON2.7 = 0 ' weak pullups on
INTCON.1 = 0 ' INT0IF
INTCON.4 = 1 ' INT0IE
INTCON2.6 =0 ' INTEDG0 falling edge trigger
ADCON1 = %11110101
Write("When LED 1 lights press button #1.",13,10)
Qualify = 0
T0CON = $04 ' 1/32 prescaler on timer 0, 16 bit mode
TMR0L = 0 ' clear the timer
TMR0H = 0
LED(3) ' Ready
DelayMS(1000)
INTCON.1 = 0 ' clear the interrupt flag
Enable(ButtonPress)
LED(2) ' Steady
DelayMS(500)
Qualify = 1 ' don't disqualify yourself by pressing too early
T0CON.7 = 1 ' start the timer
LED(1) ' GO
DelayMS(1000) ' 1 second timeout
INTCON.4 = 0 ' too slow disable interrupt
LED(5)
Write("Too Slow, press RESET to try again.",13,10)
While true
Wend
End
