Really Desperate of your help...
Jas
Hi :)
i need to come out with a pulse generator..
so i went to search on the net..
n i get this circuit..
it's at
https://www.electro-tech-online.com/custompdfs/2005/05/CI-3-pulse.pdf
can anyone pls help me?
it's quite urgent..
i tried stimulate the circuit using workbench..
when i activate the circuit..
it doesn't come out like wat it said in the article..
i'm supposed to get a pulse when i press switch 1 but instead i get a continuous pulse..
this goes same with the other switches..
pls help me...
Thank you so much..
really in need,
-Jaseslin-
attachment include..
hi:)
this is the ckt in workbench..
hope you can help me...
thank you:)
-Jaseslin-
  • 123_109.zip
Hi, if all you need is a single pulse, it's easy, just hook a cap about .1 mf or so in series with a test probe, touch your probe to a 5 volt source, and then to the input you need to pulse, you can vary the pulse duration by varying the size of the cap, if you have a scope, you can observe the result.
