Gandledorf
What is the reasoning behind 8ohm speakers, and why this measurement is important? It seems like this would be awfully difficult to drive...
ljcox said:I'm not sure I understand the question. I assume you want to know why speakers need to be a specific impedance.
It is because the speaker impedance must match the output impedance of the amplifier in order to obtain maximum power transfer.
So if the amp is designed for an 8 ohm output impedance, then you will obtain maximum power into an 8 ohm speaker.
Len
ljcox said:I don't know what you mean by "If I were to design a microcontroller based system, with a speaker"
Len
Russlk said:Another, and probably most important reason that speakers are 8 ohms, is that the coil is attached to the diaphram of the speaker. A high impedance would require more turns of wire, and the weight would affect the sound.
pike said:A speaker rated at 8 ohms doesn't neccessarily mean it is 8 ohms, my dads hi-fi system is rated at 8 ohms but the speakers are actually 6.3 ohms!!! but this will change from cone to cone so do your maths guys!
Exo said:It could also be that you're playing music so loud that the speaker's coil is starting to be shorted out at some places![]()
stevez said:Like many standards I'd guess that 8 ohms became a "standard" as a result of evolution. As suggested in some posts - something different could be made to work. Maybe the 8 ohms was the result of what they could make economically at the time given the materials, technology, etc. Because the capital investment in manufacturing equipment is high it's often less expensive to leave some things as they are even though at some point it would appear that the standard is less than optimal.
Just about every domestic radio used 3ohm speakers.Nigel Goodwin said:.......For a valve amplifier, it doesn't matter much - you simply wind the secondary on the transformer so it matches. In fact, 16 ohm speakers were the most common back in those days......
pebe said:Just about every domestic radio used 3ohm speakers.
