Recommendations for suitable solar panels
charlesli
Is there a solar panel suitable for 12v powered HMI?
This is HMI's schematic.
What ever solar panel you use you will need to supply the display with a regulated supply. This would normally involve a battery and power module.
Edit, what communication protocol does that display use without a clock line?
Those Stone units are a "Smart HMI" system, they are programmed separately then all the interaction with the end system is via RS232 serial.
