Reed Switch
kid
i need the datasheet of reed switch...i dont understand how can i connected the reed switch and the small magnet bar on the veroboard? :?
here i show the circuit with using reed switch and the small magnet bar..
Personal Alarm
________________________________________
Small, portable, anti-bag-snatching unit
Also suitable for doors and windows control
Parts:
R1____________330K 1/4W Resistor
R2____________100R 1/4W Resistor
C1_____________10nF 63V Polyester or Ceramic Capacitor
C2____________100µF 25V Electrolytic Capacitor
Q1____________BC547 45V 100mA NPN Transistor
Q2____________BC327 45V 800mA PNP Transistor
SW1____________Reed Switch and small magnet (See Notes)
SPKR___________8 Ohm Loudspeaker (See Notes)
B1_____________3V Battery (two A or AA cells wired in series etc.)
Device purpose:
This circuit, enclosed in a small plastic box, can be placed into a bag or handbag. A small magnet is placed close to the reed switch and connected to the hand or the clothes of the person carrying the bag by means of a tiny cord.
If the bag is snatched abruptly, the magnet looses its contact with the reed switch, SW1 opens, the circuit starts oscillating and the loudspeaker emits a loud alarm sound.
The device can be reverse connected, i.e. the box can be placed in a pocket and the cord connected to the bag.
This device can be very useful in signalling the opening of a door or window: place the box on the frame and the magnet on the movable part in a way that magnet and reed switch are very close when the door or window is closed.
Circuit operation:
A complementary transistor-pair is wired as a high efficiency oscillator, directly driving a small loudspeaker. Low part-count and 3V battery supply allow a very compact construction.
Notes:
• The loudspeaker can be any type, its dimensions are limited only by the box that will enclose it.
• An on-off switch is unnecessary because the stand-by current drawing is less than 20µA.
• Current consumption when the alarm is sounding is about 100mA.
• If the circuit is used as anti-bag-snatching, SW1 can be replaced by a 3.5mm mono Jack socket and the magnet by a 3.5mm. mono Jack plug having its internal leads shorted. The Jack plug will be connected to the tiny cord etc.
• Do not supply this circuit at voltages exceeding 4.5V: it will not work and Q2 could be damaged. In any case a 3V supply is the best compromise.
**broken link removed****broken link removed****broken link removed**
Dry Type
Wire Type
