MrMikey83
I am using the Analog brand Gyro Sensor ADXRS300 with an ATmega32. The sensor has a reference voltage output that can be used to take more accurate measurements.
The sensor is 2.5 volts on the output at rest and varies 2.25 volts above or below that when the sensor is turned.
I originally had 5 volts on the Aref and it worked fine, but I would like to use the sensors Vref to provide a more accurate sensor reading from the Gyro. How can I use the 2.5 volt sensor reference to provide a reference for the ADC of the ATmega32.
My guess is that I need to double the sensor reference voltage while still keeping it accurate...but how?
~Mike
~Mike
