struct{
unsigned SW1 : 1;
unsigned SW2 : 1;
unsigned SW3 : 1;
unsigned SW4 : 1;
unsigned SW5 : 1;
unsigned SW6 : 1;
unsigned SW7 : 1;
unsigned SW8 : 1;
}dip8;
if(dip8 && 0x01) SW1 = 1;
if(dip8 && 0x02) SW2 = 1;
if(dip8 && 0x04) SW3 = 1;
if(dip8 && 0x08) SW4 = 1;
if(dip8 && 0x10) SW5 = 1;
if(dip8 && 0x20) SW6 = 1;
if(dip8 && 0x40) SW7 = 1;
if(dip8 && 0x80) SW8 = 1;
struct{
unsigned SW1 :1;
unsigned SW2 :1;
unsigned SW3 :1;
unsigned SW4 :1;
unsigned SW5 :1;
unsigned SW6 :1;
unsigned SW7 :1;
unsigned SW8 :1;
}dip8;
//USAGE
dip8 temp;
temp.SW1 = 1;
if(temp.SW2 == 0)
//BIT 2 is low
/* Bit Operation macros */
#define sbi(b,n) ((b) |= (1<<(n))) /* Set bit number n in byte b */
#define cbi(b,n) ((b) &= (~(1<<(n)))) /* Clear bit number n in byte b */
#define rbi(b,n) ((b) & (1<<(n))) /* Read bit number n in byte b */
#define fbi(b,n) ((b) ^= (1<<(n))) /* Flip bit number n in byte b */
#define bit_is_set(b,n) (b & (1<<n)) /* Test if bit number n in byte b is set */
#define bit_is_clear(b,n) (!(b & (1<<n))) /* Test if bit number n in byte b is clear */
void main(void)
uint8_t dip8;
sbi(dip8, 0); /* Set bit number 0 */
cbi(dip8, 7); /* Clear bit number 7 */
fbi(dib8, 4); /* Flip bit number 4 */
if(bit_is_set(dip8, 0))
/* Bit number 0 was set */
if(bit_is_clear(dip8, 2))
/* Bit number 2 was clear */
Yes, this why I do not like to use typedefs (with structs). It can get confusing fast.Jason.... If you Typedef the struct.... However I haven't.. The struct has no identifier so dip8 is a struct variable..
// Define the typedef
typedef struct
unsigned SW1 : 1;
unsigned SW2 : 1;
unsigned SW3 : 1;
unsigned SW4 : 1;
unsigned SW5 : 1;
unsigned SW6 : 1;
unsigned SW7 : 1;
unsigned SW8 : 1;
}dip_t;
// Declare the variable
dip_t dip8;
// Use the variable
dip8.SW1 = 1;
// Define the struct
struct dip
unsigned SW1 : 1;
unsigned SW2 : 1;
unsigned SW3 : 1;
unsigned SW4 : 1;
unsigned SW5 : 1;
unsigned SW6 : 1;
unsigned SW7 : 1;
unsigned SW8 : 1;
struct dip dip8;
// Use the variable
dip8.SW1 = 1;
struct
unsigned SW1 : 1;
unsigned SW2 : 1;
unsigned SW3 : 1;
unsigned SW4 : 1;
unsigned SW5 : 1;
unsigned SW6 : 1;
unsigned SW7 : 1;
unsigned SW8 : 1;
}dip8;
// Use the variable
dip8.SW1 = 1;
typedef struct dip
unsigned SW1 : 1;
unsigned SW2 : 1;
unsigned SW3 : 1;
unsigned SW4 : 1;
unsigned SW5 : 1;
unsigned SW6 : 1;
unsigned SW7 : 1;
unsigned SW8 : 1;
}dip_t;
dip_t dip8;
struct dip dip9;
Oh, the horror, if somebody actually does thatOr, you can use both..
Oh, the horror, if somebody actually does that.
typedef union {
struct {
unsigned C :1;
unsigned DC :1;
unsigned Z :1;
unsigned nPD :1;
unsigned nTO :1;
unsigned RP :2;
unsigned IRP :1;
struct {
unsigned :5;
unsigned RP0 :1;
unsigned RP1 :1;
struct {
unsigned CARRY :1;
struct {
unsigned :2;
unsigned ZERO :1;
} STATUSbits_t;
extern volatile STATUSbits_t STATUSbits @ 0x003;
