Regarding Antenna
gautam cs
Hello,
i am using 434 MHz Tx and Rx.
antenna is the problem. which antenna i should use.
simple wire can i use as a antenna or not.
Lots of good 433Mhz antenna info in this thread..
Minimal simplistic antenna is a center-fed 1/2λ dipole; or a 1/4λ monopole operated against a 1/2λ by 1/2λ conductive ground plane.
What works very poorly is 1/4λ monopole operated against NO ground-plane
