Ok this might be a bit more on the mechanical side but, I want to do regenerative breaking with a go-cart. I have two gear-wheels with a belt drive. The smaller wheel is driven by the motor which effectively rotate a bigger gear-wheel through a belt which in turn rotate the wheels of the go-cart. Now iv read somewhere which iv referenced that you cant do regenerative braking due to some tension problems(look at reference under “toothed belts”. They only mention toothed belts however, but does that apply to chain belts (The ones used in bicycles for example) as well. Reading the theory about it, makes me think that it does, but just want to check
Referense
https://www.4qd.co.uk/faq/bmnc4.html#surge
located under toothed belts down the buttom.
Referense
