Nany
I'm working on a simple automatic watering circuit..
here the circuit...
one of the probe (sensor) is connected to the -ve side and the other is connected to the input of the variable resistor.
I connected 2 legs of the variable resistor. the middle as input with the amplifier, and the other with +ve side.
the common of the relay is connected with +ve, and the LED (as a pump) with the normal open.
the pump is supposed to work when soil is dry and stop if wet.
but .. when i put the probe in dry soil , the pump work and never stop,,, even if the soil is really wet,,
i hope you can help to know where is the problem.....
thank you.
here the circuit...
thank you.
