relay or???
hjl4
Which is more suitable? In my circuit, I have a PIC 12F675 acting as a 2.5hr timer(running thru delay), and when the (delay)/timer has run out, the pin GPIO2 goes low. But during the time that the pin is high(2.5hr), I have 24 vdc going to a set of batteries, thru a relay, or a transistor. No more then 2 amps.
Which would be more efficient? The relay or the transistor? You must of figured out already, that the PIC is running the relay or transistor.
I hope this is clear enough.
Hey Nigel, think of it as the PIC gives a signal (high) to either a relay or transistor to keep a valve open. The valve is held open until the timer runs out. What I want to know is which uses the least amount of power to actuate the valve, The relay, or the transistor.
For 2A you could use a TIP31A transistor. At a collector current of 2A its base current should be 200mA but it will work (not good) if the base current is only 100mA.
A 2A relay needs a coil current of about 40mA at 12V.
A Mosfet doesn't need any current to turn it on very well.
OK Audio, It's what I thought, but again just double checking to make sure.
I thought for sure a Darlington transistor would use less energy to keep the flow of current going from collector to emitter, instead of a relay mechanically latched and held that way to do the same thing.
I guess a Mosfet can also do.
Just needed to be clear on this, as relays are expensive.
Thanxs
I see what you mean blueroom, but trying to keep cost low as possible. I will go with Darlington, and see what gives.
Thanks for input.
Yes under $10. I checked Digikey, and cheapest was $15 from OMRON(Latch Relay).
The whole board has to be under $10. A PIC, a Darlington and a few resistors and caps, and that's it.
I should acheive that no problem with a darlington transistor.
I hate these budget projects from the company I work for.
Anyways, Thanks.
The IRLZ34NPBF-ND FET at DigiKey costs $2.12 CDN and will switch up to 30 Amps. It has a max RDS on of 0.06:ohm: at 14 Amps with a gate-source voltage of 4V. As long as you can switch the (-) side of the solenoid, this should work fine. I'm sure if you browsed DigiKey longer than I did that you could find one that would work for even cheaper. Don't forget the catch diode! ;)
