cashcory08
does anyone know of such remotes and receivers that i can use to control a 6v motor by simply placing the receiver between the battery and motor?
I believe it's a 3~6 volt motor powered by a 6v rechargeable battery with 4.5Ah, max voltage of 7.5v
i want to try this,
Because i want it as cheap as possible because i need up to ten receivers
but i dont know if it will work since its operating voltage doesn,t match perfectly with the motor or battery specifications... i dont think the motor draws much amperage but im not sure..
This is the motor... **broken link removed**
i want to try this,
