Hello All,
I am doing a project and I am responsible about safety for aquarium light system, I am supposed to have a moisture detector ( Could not find online) that detects if the prototype falls in the water of the aquarium. If it did, the sensor then sends a signals to open up the MAIN power supply which will result in shutting down the whole system including the moisture detector (since I am getting my power from the MAIN power supply) so I guess I will need my own power supply probably. For the circuit breakers, I have a “Latch Relay” dual coil switch (DSP1-L2-DC5V)that has a magnet where it will save the last state it had before tripping so the user can not reset the system by just plugging and unplugging the wire in the outlet. I will also have two mechanical push buttons, one normally open and one normally closed to be able to reset the system manually. I also need Remote Control Circuit Breaker (RCCB), I have searched for RCCB for over a week now and could not find one that has current rating between 60 mA to 250 mA. They all operate with current ratings from 5A to 100A which is away from ideal for my project.
Please, I need help in finding:
1) Moisture Detector
2) Remote Control Circuit Breaker: Current Rating between 60mA and 250 mA
Thank you
Thank you
