Removing gel pot for lamp body repair
Jaimesix
Hi
I have these LED lamps (auxiliary off road lamps) that are a (supposed to be) good brand
Fact is the body is aluminum and it is rusting turning into white powdery corrosion on its surface
Decided to pull them apart to try blast and refinish the aluminum body
Discovered inside these lamps have this gel pot, so I am thinking about taking it off (no option if I were to want to refurbish the body) in order to do as mentioned.
Am I just use a knife and get it off? So that after painting the lamp bodies I could reapply it ?
Is this gel readily available for reapplication ?
Any experience with dealing with corroded aluminum bodies so common nowadays?
After this experience I’d rather have steel or plastic bodies as opposed to aluminum
So is the gel those white squiggles that look like they hold the lamp module to the enclosure? If so, I'd just scrape it off like you proposed, get both surfaces as clean as possible, then apply some adhesive to hold it together. I'm guessing something like silicone caulk (or even non-silicone, like what we have in the US called "Liquid Nails") should work fine. There are no electrical concerns that I can see; it's just bonding the lamps to the housing.
To get rid of the corrosion, try soaking the aluminum in vinegar.
