Oznog
Active Member
I have a couple of Lamina light engines that I initially tried out by applying heat sink grease to the back. Now I want to attach them permanently to a project with thermal epoxy. I will not be using additional mounting hardware (screws, etc) to hold it down so that epoxy bond has to be good.
So I need to clean off this grease completely to ensure the epoxy bonds correctly. How do I clean this up? Isn't this a silicone base? Even alcohol, actone, thinner, etc usually have no effect on silicone, it doesn't work as a solvent and is like trying to clean up grease with water.
