Repair GymBoss MiniMax
Cthulien
Reference to the following post if someone is looking for it.
I have the same issue without the water damage. My gym boss minimax started vibrating constantly and then died. I opened it today and found that also in mine the Inductor broke to pieces and one wire was loose. (It appears to be a common problem. I found the same issue in one Amazon review)
I just wanted to leave here that I suppose it's this inductor:
Burns: SDE0403A-330K costs less than a euro/dollar.
So if someone else is looking for this. Here you go.
Happy fixing
I tried to fix it with the inductor. I used a current limited power supply to test if it was successful. However, Current consumption was higher than 400mA in startup. From that I judged something else is broken.
