Repairing PSU components in Technics SB-AS500 ACTIVE SUB Power supply
jonbonse
Hi all
I am fairly new to repairing electronics am was hapy to find this forum.
I hope I can be helped!
The power supply in my active sub has blown as my son flicked the red switch from 220v down to 110v whilst switched on!
The glass fuse has blown which is easy to source and replace, however there is a 3 leg IC blown to bits and can only work out parts of the markings on it. I am uncertain where to get a replacement.
The markings are as follows:
TOP227
81877B
PHIL
I have performed a search on '81877b TOP227' but nothing comes up except for just 'TOP227' on its own.
Can I simply replace this IC with any 'TOP227' IC?
Looking forward to your input!
Many thanks
The TOP227 is a 150Watt PWM switch, just replace it BUT check other components around it for damage or shorts or you will take out the new one.
Hope the PDF file is usable. What you have is a TOP227Y, the Y is a TO220 3term device & this is what you need.
  • TOP221_227 PWM switch.pdf
