Hi, I am new to this forum so bear with me. I am buying a couple of 'dice' kits which run LEDs. This circuit seems to fit the bill! What I want to know is if I replace each LED with a MOC3021 optocoupler triac driver, or similar, will the circuit still work (as there are 2 led's in series) and can the output switched side of the MOC3021 then be used to switch an ac circuit of 12 volt. by direct connection. And the switching will occur in the same manner the original LEDs in the circuit would?
