Hello all,
It's been a while since my last post and I have a question for the guru's out
there.
I have a chaser light kit that had been put together and worked fine.
Through bad storing on my part the crystal that was on it broke off and there
isn't enough of 1 lead to put it back on. I need a new one.
It's a 12v dc kit using a pre-programmed ic for 10 patterns.
The ONLY spec that came with the kit for the crystal was the it is
a x'tal crystal that is 12 mhz.
The place I got this from has long since been out of business and I can't seem
to locate this specific crystal.
So I put it to the guru's, can I use pretty much and 12 mhz crystal in it's place so the chaser light kit will work again?????????????
Craig
there.
Craig
