Replacement for CA3160
CA3160 = TLE2141 Search this document for all matches to TLE2141 there are many.
CA3160 replacement.
Hi Alisarhangpour,
That's a tricky one, it's not particulary fast or precise but it has several
advantages over other opamps. It's a bimos opamp with mosfet inputs
intended for single supply applications. Both inputs can work 0.5 volts
below the most negative supply rail and it has a strobe input which can
be used to switch off the output stage, ( max. positive output voltage)
or even "wire or" it with another CA3160. Stick to the CA3160 or give us
a schematic of the application.
on1aag.
Here is the Datasheet
  • CA3160_fn976.pdf
