I see the reply with quote buttons and like the feature as seen in other peoples posts, but I don't know how to use it. Rather than make a bunch of multiple posts I thought it might be better to ask how to use them.
press the button
This is after the last square brackets with the not-quote command.Maybe it's multiple quotes I didn't understand. I tried the regular one on a multi-subject paragraph but it sticks my reply in with the quote. See repeal health care reform in members lounge.
This is after the not-quote.[QUOTE This is a test to see what happens if I type after a square bracket quote.
Post 2I see the reply with quote buttons and like the feature as seen in other peoples posts, but I don't know how to use it. Rather than make a bunch of multiple posts I thought it might be better to ask how to use them.
Post 3Just press the button and type.![]()
Hi Ronv,You should be able to edit the quote, with care, to only quote the main point.
the OP said:This was posed by the OP (original Poster)
[/B]
renders as:
[quote}The tags necessary are in bold. Bold is not required. Lowercase is not required. The [b]= the OP[/b] isn't required either.[/quote] is the first answer.
You can use "Go advanced" and preview your post.
[quote}"reply with quote" quotes the entire post.[/quote] 2nd reply You just have to add the tags[b] [plain] sporatically throughout the reply and check with Preview before posting.
One more time.The tags necessary are in bold. Bold is not required. Lowercase is not required. The = the OP isn't required either.
Bet this is itYou can use "Go advanced" and preview your post.
User2 said:So I was talking with this guy, see, and he said:
User1 said:Blah, blah, blah, blah, blah.
This text:
[quote=User2]So I was talking with this guy, see, and he said:
[quote=User1]Blah, blah, blah, blah, blah.[/quote]
[/quote]
You can also just use the "multi-quote this message" option (the speech bubble with quotation marks inside and a '+' sign next to it) at the bottom of each post. You click the one corresponding to each post you want to quote, then hit "reply with quote." It automatically quotes all of the posts on which you clicked "Multi-Quote this message."
Der Strom
