Greetings to all,
I am a recently-minted, like-new, rarely-used, still in original-packaging electrical design engineer and I've run into my first real stumbling block 6 months into my first job out of college.
I'm looking to build a (relatively) constant current source for pulsing a pair of IR LED's from a nominally 5V source (USB or 4AA batteries depending on use). The pulse supplier is a microcontroller off of a pin that can source and sink 20mA but only up to around the micro's regulated Vdd, which is 3.3V. Pulse rate is 36kHz with 25% duty cycle. I'm aiming at a ~350mA pulses which should develop ~3.4V drop across the pair of LED's I'm using (TSHF5210).
The circuit that I came up with (looks fairly good in simulation) utilizes the micro output running into a 75 Ohm resistor which goes to a 2.7V zener running to ground. At the resistor-zener junction is the gate of an N-MOSFET, NTK3043N whose source is at ground and drain hooked up to the bottom of one of the IR LED. There is another IR LED in series with that one before being attached to the battery voltage (4.5-6.5V expected range).
The questions I have are:
a) Is using a zener to regulate a FET like this a decent idea? I don't need it to be super-accurate and the spec-sheet for the zener claims 5% accuracy. I'm guessing I need to allow 5 or 6 mA of current to get the zener to regulate decently.
b) Does anyone know of a FET with a lower turn-on voltage? I'm looking at an equivalent circuit on a handheld remote that I would like to pulse even higher (~500mA) but only has access to 2.6-3.2V from batteries) and I can't find a FET that will turn on that hard with that low of a voltage to save my life. Currently, I'm using a design that I inherited from my predecessor that uses a pair of NPN transistors to pulse the current, but I'm running into problems with the main power transistor's turn-off time (I think it's being driven into saturation), so I wanted to see if it was possible to transfer the FET circuit over to this other device.
c) Would it be better to use a P-FET "up top", say, with an open-drain output on the micro that could pull it down to ground to turn it on and a pull-up resistor to turn it off?
My humble appreciation for any advice or help ...
Mike Webster
Mike Webster
