reldridgejr
I am rewiring an old honda 70 3 wheeler which I converted to a new model 12v engine with electric start. The only thing I am stuck on is how to wire the kill switch. It appears to be a center on switch with an up off, down off, center on (run) configuration. I believe the handle bars act as a ground because it is in a chrome housing and there are only 2 wires coming from the switch. Do I run one wire to hot and one to ground? Or do I run both to hot and let the bars act as ground? Is only one active and the other dead? I guess what I'm asking is what's the standard way a center on switch is wired on a motorcycle? Thanks for your help in advance...
