I am trying to build a 125 khz RFID reader unit and I have some question I hope someone could help me with. I need to maximise the read range of my unit but I am slightly constrained by how big I can make the reader coil. So, the only thing I can do is use a more powerful amplifier. I have been looking at the RFID reference design manual from Microchip and it has been a lot of help in designing my circuits. But I have one question regarding the interpretation of a paragraph in page 133 of the manual (https://ww1.microchip.com/downloads/en/DeviceDoc/51115F.pdf):
Would I need to just replace the 2n22222 transistor with a mosfet and stick a push-pull driver in front of it?
I was also looking into circuits such as figure 2 shown here https://www.daycounter.com/Circuits/HV-MOSFET-Driver/HV-MOSFET-Driver.phtml
Also, another limitation I have is I need to be able to power my whole reader unit by using a 9V battery. Would it be useful to have a mosfet amplifier instead of the one given in the Microchip document?
Is there any other things I could do to increase the read range of the reader? Does anyone know of any sites with suitable example circuits I can play around with?
I should also mention that my whole design will need to be analogue as I will be doing some signal processing on the received tag signal.
Many thanks for reading.
For long read-range applications, this power amplifier
circuit can be modified. Power MOSFETs may be used
instead of the bipolar transistors (2N2222). These
power MOSFETs can be driven by +24 VDC power
supply. A push-pull predriver can be added at the front
of the complementary circuit. This modification will
enhance the signal level of the carrier signal and the
read range of the ASK Reader.
