RGB Compact Format
Suraj143
Active Member
I'm doing a Neo pixel project & I want to deal with 3byte colour variables.For PIC micros I need a compact way of save RGB colours in a Table read instead of 3 bytes.Mike (Pommie) proposed me the 332 format (RRRGGGBB).
Need some advice regarding 332 method.Does it have 7 levels for Red, Green and 3 levels for blue?
If you're curious how this looks, go to this page and copy this code into it,
<!DOCTYPE html>
<html>
<body>
<img id="scream" src="img_the_scream.jpg" alt="The Scream" width="220" height="277">
<canvas id="myCanvas" width="220" height="277" style="border:1px solid #d3d3d3;">
Your browser does not support the HTML5 canvas tag.</canvas>
<script>
document.getElementById("scream").onload = function() {
  var c = document.getElementById("myCanvas");
  var ctx = c.getContext("2d");
  var img = document.getElementById("scream");
  ctx.drawImage(img, 0, 0);
  var imgData = ctx.getImageData(0, 0, c.width, c.height);
  // invert colors
  var i;
  for (i = 0; i < imgData.data.length; i += 4) {
    imgData.data[i] = (imgData.data[i]+16) & 0b11100000;;
    imgData.data[i+1] = (imgData.data[i+1]+16) & 0b11100000;
    imgData.data[i+2] = (imgData.data[i+2]+32) & 0b11000000;
    imgData.data[i+3] = 255;
  ctx.putImageData(imgData, 0, 0);
</script>
<p><strong>Note:</strong> The canvas tag is not supported in Internet
Explorer 8 and earlier versions.</p>
</body>
</html>
When you press run it copies the picture into the 332 format. You can see the difference but if they wern't side by side I doubt you could tell which was which.
P.S. Hope the above works. First time trying.
Edit, changed the code to stop it making the picture darker.
That "improved" code caused some wrapping around of colours. This avoids that,
<!DOCTYPE html>
<html>
<body>
<script>
  // invert colors
  var i;
      if(imgData.data[i]<(256-16))
    else
        imgData.data[i] = imgData.data[i] & 0b11100000;
      if(imgData.data[i+1]<(256-16))
    else
        imgData.data[i+1] = imgData.data[i+1]+16 & 0b11100000;
      if(imgData.data[i+2]<(256-32))
    else
        imgData.data[i+2] = imgData.data[i+2] & 0b11000000;
</script>
</body>
</html>
Hi, I'm about to write my new RGB project & going to use 332 format to show colours using a single byte.
I extracted a single byte & below shows the brightness levels.
Single byte Format
b1 b0 g2 g1 g0 r2 r1 r0
r2 r1 r0
001 =4 (low bright)
010 =8
011 =16
100 =32
101 =64
110 =128
111 =255 (hi bright)
b1 b2
00 =4 (low bright)
01 =32
10 =128
11 =255 (hi bright)
I can show many of colours. But my point is for red & green I can show dim levels upto 7 stages because it has 3 bits wide.
but for blue I can only show dim levels upto 4.
Is there any method to show more dim levels in colour blue?
The reason the blue has only 4 levels is the human eye can't distinguish blue as good as it can red and green.
Here's the 888 version of the scream.
And here's the 332 version.
I can tell the difference but only if they are both shown. Images are from the above code.
Edit, the levels should just be moved into the most significant bits of the colour. So blue = 0,64,128,192 - the other (lower) bits can be zero or one depending on choice. You can of course vary the intensity by moving where the MSB is in the 8 bit version.
