Recently I've been fiddling around with this RGB LED board out of an Illuminated Arcade Joystick. Right now, it has a set of pre-programmed sequences that light up different LED combinations and change the overall RGB colour. This is all controlled by transistors carrying the supply voltage and this unknown chip that supplies the control voltage to the transistors. I am unsure of what the chip is, but after some poking around, I am somewhat suspicious that it may be something called a CAN BUS. I am probably wrong
I have attached an image of the real life PCB and a quick mock up that I did in CAD. Bear in mind, the germanium diode and C1 are of unknown values, but I think they're only for voltage sanitation. If you can help, I would greatly appreciate it![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
