I'm building a circuit to control a relay through the parallel port of my computer.
Basically, the parallel port sends bits to drive a transistor. That transistor allows a 12 VDC to flow in the coil of the relay. So when the relay is energized, the relay closes the AC contacts and a light bulb can flow.
My question is if I can damage the parallel port, since I know parallel port work from 5 VDC to 9 VDC (depending the model) and the battery voltage is 12 VDC.
Is like this:
A software controls the light bulb through a transistor and a relay.
Is like this:
