I'm working on a 2-part device (ECU and keypad) that currently use a ribbon cable to interconnect. I'm working on changing this to a true ethernet interface w/TCP/IP stack and everything.
The only catch is that I need to get power to the keypad device since it needs to power a PIC, LCD display, ethernet controller chip, etc.
The RJ45 ethernet standard only uses 4 of the 8 wires in a Cat5 bundle, but from what I gather many designs like to take those other 4 wires and ground them to provide EMI reduction on the line.
I'd like to be able to give users the freedom to disconnect the keypad and plug in a laptop and be able to access the ECU via a very simple web interface.
Where my problem comes in is that if I pass a +5v signal (or even +3.3v) over one of those wires than I risk sending that current straight into a laptop's ground.
Obviously I could put in a manual control such as a jumper on the PCB that would turn on or off the power on the pin, but that would be a royal pain in the butt to the user.
Is there a way to put in some type circuit or device that would cut off power to that pin/wire automatically if it sensed too much current was being drawn? What kind of effect would it have on a laptop if I dumped +5v into ground on what is probably a mostly 3.3v system?
Thanks,
Ray
Thanks,
Ray
