''robot based on microcontroller''
mohammed elzaq
i have to do project ''robot based on microcontroller''
so, please help me to take adecision for the jobs of this robot.
if you supply me by circuits , please do. '
thanks
you can make a line follower. its really simple in construction and you just have to control two motors and get data from a simple optical sensor. then you can add improvements to the design like bumper switches and proximity sensors.
you can get alot of info for such a robot. just google and see for yourself. the EPE magazine did a great series on robotics this year. you should check that magazine.
but whatever you do, dont copy the whole design. try to make something yourself.
i hope that helps
Help you in what?
Select a project?
Selecting a project should be your choice and the challenges that follows it, make it more interesting.
I recommend you come up with a project. Btw, you are lucky if you choose your project. In most universities the project will be offered and you should do it. Many universities now a days do similar project again and again? what is the point?
Did you benfit anyone? Ok you learn how to copy a project and do it? or learn the concept?
But i recommend doing a Project which is new using old concepts is ok, but try being creature and innovative that what give you fame and reputation.
Best regards,
Hesham Ismail
help compile
anabody can help me to compile this to hex program language. i don't know how to compile this language and what software use.
'Slowspeed
'Manual control of five servomotors using 5 SPDT switches
'Microcontroller PIC 16F873
adcon1 = 7 'Set port a to digital I/O
'Declare variables
b0 var byte 'Use b0 as hold pulse width variable for servo 1
b1 var byte 'Use b1 to hold pulse width variable for servo 2
b2 var byte 'Use b2 to hold pulse width variable for servo 3
b3 var byte 'Use b3 to hold pulse width variable for servo 4
b4 var byte 'Use b4 to hold pulse width variable for servo 5
b6 var byte 'Variable for pause routine
b7 var word 'Variable for pause routine
s1 var byte 'Unassigned delay variable
s2 var byte 'Assigned delay variable
'Initialize servomotor variables
b0 = 150 'Start up position servo 1
b1 = 150 'Start up position servo 2
b2 = 150 'Start up position servo 3
b3 = 150 'Start up position servo 4
b4 = 150 'Start up position servo 5
s2 = 4 'Delay variable
start:
'Output servomotor position
portb = 0 'Prevents potential signal inversion on reset
pulsout portb.7, b0 'Send current servo 1 position out
pulsout portb.6, b1 'Send current servo 2 position out
pulsout portb.5, b2 'Send current servo 3 position out
pulsout portb.4, b3 'Send current servo 4 position out
pulsout portb.3, b4 'Send current servo 5 position out
'Routine to adjust pause value (nom 18) to generate approx 50 Hz update
b7 = b0 + b1 + b2 + b3 + b4
b6 = b7/100
b7 = 15 - b6
pause b7
'Check for switch closures
if portc.3 = 0 then left5 'Is sw1 left active?
if portc.2 = 0 then right5 'Is sw1 right active?
if portc.1 = 0 then left4 'Is sw2 left active?
if portc.0 = 0 then right4 'Is sw2 right active?
if porta.5 = 0 then left3 'Is sw3 left active?
if porta.4 = 0 then right3 'Is sw3 right active?
if porta.3 = 0 then left2 'Is sw4 left active?
if porta.2 = 0 then right2 'Is sw4 right active?
if porta.1 = 0 then left1 'Is sw5 left active?
if porta.0 = 0 then right1 'Is sw5 right active?
goto start
'Routines for servomotor 1
left1:
s1 = s1 + 1
if s1 = s2 then
b0 = b0 + 1 'Increase the pulse width
s1 = 0
endif
if b0 > 254 then max0 'Maximum 2.54 milliseconds
goto start
right1:
s1 = s1 + 1
if s1 = s2 then
b0 = b0 - 1 'Decrease the pulse width
s1 = 0
endif
if b0 < 75 then min0 'Minimum .75 millisecond
goto start
max0:
b0 = 254 'Cap max b1 at 2.54 milliseconds
goto start
min0:
b0 = 75 'Cap min b1 at .75 millisecond
goto start
'Routines for servomotor 2
left2:
s1 = s1 + 1
if s1 = s2 then
b1 = b1 + 1 'Increase the pulse width
s1 = 0
endif
if b1 > 254 then max1 'Maximum 2.54 milliseconds
goto start
right2:
s1 = s1 + 1
if s1 = s2 then
b1 = b1 - 1 'Decrease the pulse width
s1 = 0
endif
if b1 < 75 then min1 'Minimum .75 millisecond
goto start
max1:
b1 = 254 'Cap max b1 at 2.54 milliseconds
goto start
min1:
b1 = 75 'Cap min b1 at .75 millisecond
goto start
'Routines for servomotor 3
left3:
s1 = s1 + 1
if s1 = s2 then
b2 = b2 + 1 'Increase the pulse width
s1 = 0
endif
if b2 > 254 then max2 'Maximum 2.54 milliseconds
goto start
right3:
s1 = s1 + 1
if s1 = s2 then
b2 = b2-1 'Decrease the pulse width
s1 = 0
endif
if b2 < 75 then min2 'Minimum .75 millisecond
goto start
max2:
b2 = 254 'Cap max b2 at 2.54 milliseconds
goto start
min2:
b2 = 75 'Cap min b2 at .75 millisecond
goto start
'Routines for servomotor 4
left4:
s1 = s1 + 1 'Increase the pulse width
if s1 = s2 then
b3 = b3 + 1
s1 = 0
endif
if b3 > 254 then max3 'Maximum 2.54 milliseconds
goto start
right4:
s1 = s1 + 1
if s1 = s2 then
b3 = b3-1 'Decrease the pulse width
s1 = 0
endif
if b3 < 75 then min3 'Minimum .75 millisecond
goto start
max3:
b3 = 254 'Cap max b3 at 2.54 milliseconds
goto start
min3:
b3 = 75 'Cap min b3 at .75 millisecond
goto start
'Routines for servomotor 5
left5:
s1 = s1 + 1
if s1 = s2 then
b4 = b4 + 1 'Increase the pulse width
s1 = 0
endif
if b4 > 254 then max4 'Maximum 2.54 milliseconds
goto start
right5:
s1 = s1 + 1
if s1 = s2 then
b4 = b4-1 'Decrease the pulse width
s1 = 0
endif
if b4 < 75 then min4 'Minimum .75 millisecond
goto start
max4:
b4 = 254 'Cap max b4 at 2.54 milliseconds
goto start
min4:
b4 = 75 'Cap min b4 at .75 millisecond
goto start
end
end
this program is written in pic basic and the compiler looks something like the one in the following website,
PICBASIC Programming &mdash; Evolved | Proton Development Suite
but the free compiler they have doesnt work on all types of uC's so you have to figure a way to change the code to a similar language like C and then you will find more free compilers for C to upload the code to your ucontroller
-Ali
Hi Abhijeet.roy
You can take a look **broken link removed**. The tutorial helps you build a robot (from scratch) that drives to a light source.
Slorn
