Robot follower HELP PLZ its just small thing can't fix it :(
goldfish300
well this is my project topic:
Line follower robot; the robot has two IR sensors that detect a black line. The PIC16f628 has to read the sensor values, and compare them, and then decides if the robot should turn left or right.
well i'v done the code and im trying to fix what i have and my question is when i try to enable the switch nothing happen in which a led must turn on and i don't have an error
and also the motor right problem. so anyone can help. i will post the code with the graph and see the attachmet for the file im working with
;LINE FFOLLOWER ROBOT USING PIC16F628,L298
#INCLUDE	"P16F628A.INC"
#DEFINE		PB_FORWARD		PORTA, 0
#DEFINE		PB_STOP			PORTA, 1
#DEFINE		ENABLE			PORTA, 2
#DEFINE 	        LS_RIGHT		        PORTA, 3
#DEFINE 	        LS_LEFT			PORTA, 4
;outputs
#DEFINE 	M1L1			PORTB, 1
#DEFINE 	M1L2			PORTB, 2
#DEFINE 	M2L1			PORTB, 3
#DEFINE 	M2L2			PORTB, 4
#DEFINE 	START		PORTB, 0
	CBLOCK	0X20
	A1, A2, A3
	ENDC
	ORG 	0X000
	GOTO	MAIN
MAIN
	CALL	SETUP
	CALL 	MAIN_START
REPEAT
	BTFSC	PB_FORWARD
	CALL	        GO_FORWARD
	BTFSC	PB_STOP
	CALL	        STOP
	BTFSC	LS_LEFT
	CALL	        SENSOR_LEFT
	BTFSC	LS_RIGHT
	CALL	        SENSOR_RIGHT
	GOTO	        REPEAT
GO_FORWARD
	BCF		M1L1
	BSF		M1L2
	BCF		M2L1
	BSF		M2L2
	RETURN
STOP
	BCF		M1L1
	BCF		M1L2
	BCF		M2L1
	BCF		M2L2
	RETURN
MAIN_START
	BTFSC	ENABLE
	BSF		START
	CALL 	        DELAY_10MS
	BCF		START
	RETURN
SENSOR_RIGHT
	BSF		M1L1
	BCF		M1L2
	BSF		M2L1
	BCF		M2L2
	BTFSS 	LS_RIGHT
	GOTO 	$+3
	CALL	        DELAY_10MS
	GOTO        $-3
	CALL	        GO_FORWARD
	RETURN
SENSOR_LEFT
	BCF		M1L1
	BSF		M1L2
	BCF		M2L1
	BSF		M2L2
	BTFSS 	LS_LEFT
	GOTO	        $+3
	CALL	        DELAY_10MS
	GOTO         $-3
	CALL	        GO_FORWARD
	RETURN
DELAY_10MS
	MOVLW		D'5'
	MOVWF		A1
	MOVLW		D'108'
	MOVWF		A2
	MOVLW		D'5'
	MOVWF		A3
	DECFSZ		A3
	GOTO		        $-1
	DECFSZ		A2
	GOTO		        $-5
	DECFSZ		A1
	GOTO		        $-9
	RETURN
DELAY_1S
	MOVLW 		D'46'
	MOVWF		A1
	MOVLW		D'189'
	MOVWF		A2
	MOVLW		D'37'
	MOVWF		A3
	DECFSZ		A3
	DECFSZ		A2
	GOTO		         $-5
	DECFSZ		A1
	GOTO		        $-9
	RETURN
SETUP
	CLRF	         PORTA
	CLRF	         PORTB
	BSF		STATUS, RP0
	CLRF	         TRISB
	MOVLW	B'00011111'
	MOVWF	TRISA
	BCF		STATUS, RP0
	MOVLW	B'00000111'
	MOVWF	CMCON
	RETURN
END
the PIC:
  • MROBOT.zip
the PIC:
Got your zip, trying the *.asm in Oshonsoft Sim.
Could you explain in a little more detail, the text marked in BLUE, I dont fully understand.:)
the PIC:
well i mean that when i start the robot i need to check its turn on by turning the led that can be shown in the figure. and also im having trouble with the motor right when i press on the push button it goes to the left and it must go to the right. this is what i mean . if there is anything unclear just tell me .
This is the result:
1.Power up.
> no drive to motors.
2.FWD pressed
> B2 & B4 ON
3. STOP pressed
> no drive to mtrs
4. RIGHT pressed
> no drive to mtrs
5. LEFT pressed
> B1 & B3 ON
NOTE: RA4 the ENABLE is an open drain, requires a pullup resistor, say 10K
I will look some more.
EDIT: its a fuzzy drawing I have misread a pin number.
Revised results.
assignments:
A0=fwd
A1=stop
A2= enable sw
A3=right
A4=left
B0=led
B1=right1
B2=right2
B3=left1
B4=left2
Result:
Enable & fwd = B2 & B4
Enable & right = B1 & B3
Enable & left = B2 & B4
Enable & stop = no mtrs
Note: fwd and left calling same pins!
The led on B0, appears to flash for only 10mSec.?
This is the result:
1.Power up.
> no drive to motors.
2.FWD pressed
> B2 & B4 ON
3. STOP pressed
> no drive to mtrs
4. RIGHT pressed
> no drive to mtrs
5. LEFT pressed
> B1 & B3 ON
so what i have to doin this case
4. RIGHT pressed
> no drive to mtrs
and i have fix the drawing see the attachment.
  • MROBOT.zip
Here is some changes in code and drawing
but still can't get led on :(
see the attachment.
  • MROBOT.zip
Rerun the last asm you posted.
You are turning ON the led, when the ENABLE switch is set, for only 10mSecs!!
You will not see it flash.
MAIN_START
	BTFSC	ENABLE; if enable ON then
	BSF		START; turn ON led
        ;else
	CALL 	DELAY_10MS; call 10ms delay
	BCF		START; [COLOR="Red"]ALWAYS[/COLOR] on return switch OFF led.
	RETURN
ya im using it.
but still can't fix it.
i don't know how to fix the led ??
As we point out, a 10mS flash is too short to see.
Do you want the LED on B.0 to be lit while the 'enable' switch is ON.??
yes thats what i want
A simple fix.
MAIN_START
        ;else
	BTFSS        ENABLE    ;;;;CALL 	DELAY_10MS; call 10ms delay
	BCF		START; switch OFF led.
	RETURN
If you want to change the LED on/off while the program runs, call the MAIN_START in the program
I fix that but nothing happen it still not turning on the led :(
its really make me confused
IS THERE A PROBLEM IF I TALK TO U OVER MSN OR WHAT EVER U WANT ?
If the ENABLE switch is closed, before you power up the PIC, the led should light.
Unless you call the routine again the ENABLE switch will not control the LED.
It works OK in my simulator.
Are the other push buttons working with the PIC.?
The ENABLE switch pulldown resistor is not shown on your diagram.???
well thx anyway for the hard work . its seems its not gonna work :(
i have put the pulldown resistor and ENABLE switch is closed and the led didn't turn on even after i click on the enable.
ya the pic works fine with motor and the push buttons all works except the led thing.
10x for the fast help.
peace .
peace .
The enable must be ON before you put power to the PIC.
Are you sure the led is ok,? do a test on the led with a 270R to +5v, [disconnect from the PIC B.0 before you do]
You should really have a 220R from the PIC pin to the led as standard.
As the other push buttons are doing something it means the PIC is running.
Check the B.0 pin for any change in output and the A.4 pin to ensure that your enable switch is operating the A.4 input.
Lets know what you find.:)
The LED works fine in simulation.
EDIT:
If you want to chat, click the CHAT on the menu.. I'll be there for a while.
