Grossel
Hi forum.
Have an switch with 12 connections, and there is 7 possible positions. It is taken from a small substation and had being used on the analog voltmeter to switch between meassuring L1-L2, L2-L3, L3-L1, L1-N, L2-N, L3-N and 0 (no connections between any poles).
It is pretty much the same as image of the rotary switch described on this page.
Using an ohm meter, I have made a simple table showing connected poles for different positions.
In left section, all numbers enclosed into a rectangle is what I hve defined as poles that are connected. So for example if the position of the switch is "L1-L2", then there are three groups of poles that are connected: pole 2 and 4, pole 3-7-9-11, and pole 1-5-9-10.
The three sub tables to the right is just me trying to see if that appears more easy to read - probably not.
My challenge is that I want to draw the switch into a chematic, but in a way so that it show the connections between the poles.
I do find a lot of images when google for "rotary switch symbol" but none of those drawings cover rotary switches that have groups of connections. If possible, I want to avoid using multi-color schematic, but only if possible.
